  New Posts New Posts RSS Feed - Footprint Expert 2022.04 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2022.04 Released!!
    Posted: 20 Mar 2022 at 12:10pm
2022.04 was just released!!
Updates & Bugs Fixed:
      • SMD Calculators:
        • SOD, SODFL, Side Concave Package 2-Pin – updated the assembly outline polarity marker to a chamfer
        • QFP, CQFP – Setting Pin 1 to a different pin did not relocate the Pin 1 dot correctly
      • Options:
        • Component > Surface Mount > SOD – changing the pad shape to Rectangle did not work correctly
        • Drafting > Silkscreen – added a new feature for minimum Pin 1 Dot Size
      • 3D STEP:
        • Headers – changing the Pin 1 color did not work correctly
      • CAD Interfaces:
        • Allegro/OrCAD
          • Outputting a footprint created a subfolder. Added an option for “No Library Name”
        • KiCad:
          • Fixed Thermal Pad checker-board pattern paster mask reduction.
          • Over/Under sized solder & paste mask was not translating correctly
        • PADS Standard:
          • Added a feature for Right Reading reference designator
          • Fixed an issue where the translator didn’t recognize any PADS VX versions
        • Fixed a license issue
