  New Posts New Posts RSS Feed - SOIC-8 STEP Polarization Marking
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: SOIC-8 STEP Polarization Marking
    Posted: 02 Mar 2022 at 9:23am
Hi to all,
I am using PCBL 2022.02 and working with a SOIC-8; when I create the component in Altium, running the script, the mark for pin1 doesn't appear in the STEP.
Is it configurable? I exported the demo footprint for SOIC/SOP (SOP24P65) and the mark appeared...
What I could be doing wrongly?
Thanks for your help.
Best Regards,
dramos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 9:38am
V2022.03 is available with new features and 15 bug fixes.
The 50-mil pitch SOIC that was introduced in the 1980's has a Chamfer all along the top edge in the side where Pin 1 is.
The Dot Polarity Marker did not come out until the metric pitch SOP's.
This is how you can tell the difference between a SOIC and SOP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 2:14am
Dear Tom,
As ever, I am surprised with your knowledge.
Thanks a lot! I am learning with you a lot
Best regards,
dramos
Jeromeli View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jeromeli Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2022 at 3:56am
Hi, I think you can consider changing a monitor. Maybe you can try TFT LCD. I've used it before. It's really an excellent monitor
