  New Posts New Posts RSS Feed - Footprint Expert 2022.02 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2022.02 Released!!
    Posted: 11 Feb 2022 at 1:55pm
2022.02 was just released!!
Updates & Bugs Fixed:
    • Options:
      • Added a new Drafting > Silkscreen > All Density Levels
      • Allow Expanded Outline – this is for mini chip packages
    • Calculator Component Families:
      • DPAK:
        • Manufacturer Recommended Pattern dimension for pad size Y not working
        • Added Hide/Delete pins feature back
        • Fixed Footprint Name for Hidden and Deleted pins
        • Updated the Physical Description
      • Side Concave 2, 4 pin – fixed an issue with the silkscreen outline
      • SMD Chips – when moving from Calculator to FP Designer sometimes the courtyard would become irregular shape
      • SMD Oscillators – Silkscreen Outline was not translating to the CAD tool
      • All Families – when moving from Calculator to FP Designer the Silkscreen Outline would change Line Width
      • SMD CAPAE & Crystal – fixed a mathematical bug when using D1 & D2 to calculate L
      • Updated the Physical Description to allow users to edit it and save it and output to CAD tool
    • CAD Interfaces:
      • Altium
        • When creating Footprint Only (no 3D STEP) the import was not working correctly
        • Fixed an issue with Multipart Density Level not being produced in Footprint Name
        • 3D STEP model name is now independent from the Footprint name
    • 3D STEP:
      • Removed MELF and SOD Non-polarized Diodes Polarity Marker
