  New Posts New Posts RSS Feed - FP Designer: Pad Stack Designer
Bharat_Verma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Topic: FP Designer: Pad Stack Designer
    Posted: 11 Feb 2022 at 3:15am
While preparing one footprint for MPN :821-22-007-10-00010, we found that pad stack designer round-up hole diameter on upper limit.
As here 0.71 mm hole must be round up as 0.70 mm (nearest tool size), but here its round up as 0.75 mm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 8:35am
There is an option for through-hole pad stacks (both in Tools > Options > Terminals > Through-Hole and on the Options tab, next to the Pads tab shown in your image) that allows you to set the roundoff value for both the pads and the hole.
Adjust these values to fit your needs:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2022 at 4:25am
Hello ,
But that options are disable, i mean we can not change it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2022 at 8:49am
You Must save the Default Options (File > Save As) your file name, before you can edit them.
You cannot edit the master default Options. Save to your name first.
This page was generated in 0.230 seconds.
