Forum Home Forum Home > Libraries > Footprints / Land Patterns > OrCAD PCB
  New Posts New Posts RSS Feed - Multiple text lines on single subclass issue
rrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrix Quote  Post ReplyReply Direct Link To This Post Topic: Multiple text lines on single subclass issue
    Posted: 07 Feb 2022 at 3:53pm
When I create a footprint from Footprint Expert, it generates the *.dra file okay, but fails when trying to generate the *.psm file.  Here's the error:
Create symbol started.
 WARNING(SPMHA1-299): Create symbol multiple text lines are not supported on a single component type subclass.
    Item=1, Text= 'Dev' Layer= DEVICE TYPE/ASSEMBLY_TOP Location= (0.0000 0.0000)
    Item=2, Text= 'Ref' Layer= DEVICE TYPE/ASSEMBLY_TOP Location= (0.0000 0.0000)
ERROR(SPMHA1-291): Create symbol has been aborted.
Is there an option to either turn off creation of one or both of these two text lines; or to change the subclass they go to?
This page was generated in 1.344 seconds.
