  New Posts New Posts RSS Feed - Relative Path Support for Library Window Datasheet
ChrisChris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisChris Quote  Post ReplyReply Direct Link To This Post Topic: Relative Path Support for Library Window Datasheet
    Posted: 14 Nov 2021 at 9:54am
Does FP Expert Library Datasheet Link syntax support relative path syntax with respect to the FPX file that's open/active?
If so, I can't seem to get it to work.
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 11:15am
V2021 Footprint Expert "Datasheet" column supports https://web-link . com or any folder on your computer or network.
The computer link must include the entire path of the directory and the entire .pdf file name.
Example: C:\Documents\datasheets\OMNETICS_A29100-009.pdf
