  New Posts New Posts RSS Feed - Footprint Expert 2021.20 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2021.20 Released!!
    Posted: 12 Nov 2021 at 9:56am
2021.20 was just released!!
Updates & Bugs Fixed:
  • CAD Tool Interfaces:
    • Proteus – Removed the PADS ASCII option
    • 3D model was not creating a polarity marker
  • Options:
    • Changed the Pad Stack Rule option for Maximum Corner Radius to 0.20 mm
  • Calculators:
    • Chip – fixed an issue with contour courtyard not working properly
    • DFN’s – fixed a courtyard calculation issue
    • Convex Chip Array – fixed a pad stack calculation issue
    • Add new component families:
      • Chip – Crystal & Choke
      • Chip Array 2-Side Flat/Concave – Oscillator & Choke
      • Chip Array 2-Side Convex – Oscillator & Choke
      • Chip Array 4-Side Flat/Concave – Choke
      • Dual Flat No-Lead (DFN 2 Pin) – Antenna, Crystal, Choke, Thermistor, Varistor
      • Dual Flat No-Lead (DFN 3 Pin) – Choke, Ferrite Bead, Thermistor, Varistor
      • Dual Flat No-Lead (DFN 4 Pin) – Choke, Ferrite Bead, Thermistor, Varistor
      • Molded Body – Choke, Thermistor, Varistor
      • Side Concave Package (2, 4 Pins) – Choke, Ferrite Bead, Filter, Thermistor, Varistor
This page was generated in 0.282 seconds.
