  New Posts New Posts RSS Feed - Include Via in Thermal Pad Footprint
gvellet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gvellet Quote  Post ReplyReply Direct Link To This Post Topic: Include Via in Thermal Pad Footprint
    Posted: 01 Oct 2021 at 9:13am
In a QFN footprint with a thermal pad in the center. Is there a reason why we should not include the n vias in the thermal pad already in the footprint?
If I am not mistaken, the standard practice is that the PCB designer shall instantiate the footprint on his PCB.
Then while doing the layout he adds manually the vias in the thermal pad of each QFN package.
It seems to me like error prone and a waste of time.
Thank you,
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2021 at 9:54am
Most CAD tools cannot handle vias in Thermal Pad without a pin name.
Most CAD tools cannot move or delete vias built into a PCB library part once it's in the PCB design.
We created an entire library where every Thermal Pad had vias and put it out to our customers. Lots of complaints came in, so we removed them.
You can add vias to the Thermal Pad in FP Designer if you like.
