  New Posts New Posts RSS Feed - POD changes not reflected in output
RobVanSchelven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobVanSchelven Quote  Post ReplyReply Direct Link To This Post Topic: POD changes not reflected in output
    Posted: 31 Jul 2021 at 11:24am
Hi
Using POD 2021.12 I import a new part downloaded from POD today. I changed a few settings like Silkscreen: Clearance to pad & Silkscreen: Autogenerate Pin1.
The changes are not reflected in the generated file Shocked
A minor but the part name is not copied to the filename field.
Please advise? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 11:58am
Are you changing the Options "Locally" in a Calculator or in global "File > Options"?
Whenever you change a local setting the "Calculate" button lights up and you must select it to apply the changes.
Whenever you change the File > Options the changes will not appear in a footprint that is open.
You need to save the footprint to FPX library then make global preference changes in File > Options then open the footprint from the library and the changes will be applied because the data is being recalculated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 12:02pm
Also, Autogenerate Pin 1 Indicator only works on packages that have terminal leads outside the body.
It does not work for DFN, QFN, BGA, CGA, LGA, PQFN or packages that have the terminal leads under the body.
We recommend that you set the Pin 1 Dot Size to 0.50 and then recalculate. That works for all package types.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 12:59pm
I forgot the most important question.
What version of V2021.12 Footprint Expert are you using?
  • Pro
  • Enterprise
  • POD Builder
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobVanSchelven Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 1:06pm
Thanks for your quick reply Tom.
I use the option locally and did apply the Calculate button. I understand your message about that pin1 does not work for QFN.
However other changes like the space between silk and pad remain at 0.12 mm although i changed it to 0.2mm It also don't accept a polarity indicator at the assembly drawing.
My modifications get lost after saving the library and re-open it. Maybe that is by design. I am bot sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 1:09pm
Options are not saved to FPX.
They are applied to a footprint when you open it.
I need to know what version of the program you are using so I can help you with that version.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobVanSchelven Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 1:15pm
I use Footprint Expert POD 21 (2021.12)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 1:42pm
Let me discuss this with the programming and administration team.
I don't have a POD account so I can't test the features.
But to understand you correctly, you are trying to modify a footprint downloaded from POD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobVanSchelven Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 1:48pm
Yes, i bought / download a part from POD and NEED to modify some settings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2021 at 9:05am
Download and install the latest V2021.13 Footprint Expert POD - www.pcblibraries.com/downloads
Dated 8/11/21
This should fix all the issues.
This page was generated in 0.891 seconds.
