  New Posts New Posts RSS Feed - Footprint Expert 2021.12 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2021.12 Released!!
    Posted: 26 Jul 2021 at 3:28pm
2021.12 was just released!!
Updates & Bugs Fixed:
    • Adding new FPX files to an existing library added the part to the top of the list (rather than the bottom).
    • Updating a FP Designer part row in an existing library created a duplicate row and did not update the existing row.
  • Calculators:
    • The Density Level Suffix was not generated in the footprint name.
    • The silkscreen outline was not producing the correct line width Density Level set in Console Options.
    • Pin reassignment did not work correctly.
    • After adding new pins manually to an existing FP Designer part, the Delete button was disabled.
    • Added a new button to reassign pad stack pin numbers.
    • When adding pad stacks manually, added the ESC button to stop adding pins.
