  New Posts New Posts RSS Feed - Footprint Expert 2021.10 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2021.10 Released!!
    Posted: 11 Jul 2021 at 10:02pm
2021.10 was just released!!
Updates & Bugs Fixed:
  • Calculator Component Families:
    • BGA – when changing the paste mask reduction, the calculator produced the incorrect result.
    • Quad and Grid Array packages – when entering the D & E pin qty the total was an inaccurate value until the Calculate button was selected.
    • SON – using the mfr. recommended pattern was causing pads to react differently under certain dimensions.
    • SOD – moving the Calculator SOD to FP Designer caused several missing cell data information.
    • All component families with Thermal Tabs – Tabs on Assembly produced 2 outlines.
    • All SMD component families – if the mfr. recommended pattern is being used it should remove the Density Level from the footprint name.
    • All PTH component families – there is only one Density Level for through-hole footprints and the footprint name should not indicate “Nominal Density”
