  New Posts New Posts RSS Feed - PLCC
PLCC
magnus.lictor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Topic: PLCC
    Posted: 31 May 2021 at 5:42am
Can you tell me what the D2 dimension stands for. As it is not a dimension in my datasheet but required by the footprint designer.
And, when the D2 dimension is not applicable what should I use?
regards, Charles
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 9:01am
D2 = The Terminal Lead Center.
Most PLCC mfr.'s provide that dimension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote magnus.lictor Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 11:34pm
Tom,
Thanks for your reply. Did not recognize this dimension as the Terminal Lead Center.
And you are right, that dimension is in my datasheet.
Thanx, Charles
This page was generated in 4.219 seconds.
