  New Posts New Posts RSS Feed - Pad Stack Data File
Pad Stack Data File
fjp1369 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjp1369 Quote  Post ReplyReply Direct Link To This Post Topic: Pad Stack Data File
    Posted: 17 May 2021 at 1:42am
I'm using PADS Professional software, and I'm novice,
I'm trying to create a new cell by using pads library tools, but i need to import pad stack datafile to use it in the library services.
How can I find or download the pad stack data file?
Thank You
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 9:24am
PADS Professional is Xpedition Lite.
The output in the Footprint Expert library interface should be set to "Encrypted ASCII".
Make sure the select "Save Entries as Preferences" when you edit the Footprint Expert CAD tool output menu.
Enter a folder name to dump the files:
  • FootprintName_Cell.hkp
  • FootprintName_Padstack.hkp
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjp1369 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 2:47am
Thank you,
But before setting the footprint expert library,
I need to load a pad stack data file to "Library Services" and my problem is that I don't have any pad stack data file to upload it,
I have followed the procedure represented in below link :
I will be so appreciated if you help me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 7:43am
Are you saying that Footprint Expert is not producing the padstack.hkp file?
bcarter211 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcarter211 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2021 at 8:20pm
You need to select Padstack Data File option:
This will allow you to browse to the location of your *.hkp padstack file. You need to do the same for importing *.hkp files for your cells and your parts database (parts) also.
Brad
This page was generated in 0.295 seconds.
