  New Posts New Posts RSS Feed - Footprint Expert 2021.03 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Expert 2021.03 Released!!
    Posted: 21 Apr 2021 at 11:11am
Version 2021.03 was just released!!
NOTE: The V2021.03 was available online for a few days, but a new V2021.03 build was released at the time of this post. If you already downloaded V2021.03 prior to this post, it's recommended you re-download the newer build.
NEW or Enhanced Features:
  • Updated UI. Relocated the Open & Close FPX Library buttons from the right side to the left side of the screen.
  • Updated all program splash screens to include the IEC Logo and IEC 61188-7 for Zero Component Orientations.
  • Updated all Assembly and Silkscreen Legend Ref Des to rotation 0 or 90 degrees.
  • Drill size roundoff feature added in Options > Through-hole > Terminals.
Updates & Bugs Fixed:
  • Tools > Axial Lead Calculator – fixed the pin pitch bug.
  • SMD Side Concave Package component family – the footprint name was missing the package width for 2-pin parts.
  • SMD Side Concave Package component family – the physical description was updated.
  • FP Designer Pad Stack Designer – removed the UI text “Hole Over Pad” for SMD pad stacks.
  • FP Designer Pad Stack Designer – Fixed the PTH terminal lead size. The X & Y values were swapped.
  • Move Calculator footprint to FP Designer – fixed an issue to allow pad stack editing.
  • PTH SIP component family – fixed an issue where the silkscreen legend was not translating to CAD tools.
  • Print Feature broken. Fixed an issue with the Enterprise version to allow printed documentation.
  • All component families – the maximum material condition 3D STEP model was coming out distorted.
  • All PTH component families – mfr. recommended pattern was disabled.
  • Fixed an issue with Drafting Shapes and Keep-outs vanishing after the Calculate button is selected.
  • Fixed an issue with Drafting Shapes. When you leave the Properties dialog box and reopen it, the move arrows were disabled.
  • All component families – when the Mfr. Recommended Pattern was selected, changing a package dimension was not removing the Mfr. Recommended Pattern.
  • Assembly Pin 1 Polarity – removed the arc and replaced with chamfered lines.
