Nominal/Tolerance Not Available in 2021.03 FP Pro |
chads108
Joined: 17 Oct 2012 Location: Plano, TX Status: Offline Points: 35 |
Topic: Nominal/Tolerance Not Available in 2021.03 FP ProPosted: 20 Apr 2021 at 9:22am |
I installed Footprint Expert 2021.03 free version this morning.
I noticed that the fields for Nom/Tol are not available to create footprints. I have tried selecting the different radio buttons, but it makes no difference in what is available. Is this by design, or is there some setting that needs to be done somewhere? |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Online Points: 6063 |
Posted: 20 Apr 2021 at 9:28am |
Only the Required dimensions to calculate a footprint are not grayed out.
But you can certainly enter values for Nominal and Tolerance in every calculator even though they are Grayed out cells. They are fully functional. Which component family prevents you from entering in Nominal / Tolerance values? |
chads108
Posted: 20 Apr 2021 at 9:32am |
I see that they work now. I didn't try to put values in the grayed out fields.
Thanks.
