  New Posts New Posts RSS Feed - Double sided edge connector footprint
NeilVPeers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilVPeers Quote  Post ReplyReply Direct Link To This Post Topic: Double sided edge connector footprint
    Posted: 25 Jan 2021 at 7:16am
Is it possible to specify pads on opposite side of the board when creating a fpx file? I am trying to create the "tongue" mating part for an edge connector. This requires pads on both sides of the board.
How can I do that please? It also needs a slot can this be added?
NeilVP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2021 at 9:33am
Yes, in the FP Designer Pad Stack Editor you can create a pad stack on the "Top" or "Bottom" or "Both".
You can also create slotted holes and even offset slotted hole.
This feature is only in the V2020 Library Expert Enterprise version but it will also be in the free V2021 Footprint Expert Pro and V2021 Footprint Expert Enterprise version when it's released in 2 weeks.
pzt648485640 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pzt648485640 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 2:20am
Is the DPI issue fixed in the 2021 version?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 9:36am
We cannot reproduce the DPI issue with our 4K computers.
V2021 will be released in 2 weeks.
SWB01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SWB01 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 11:13am
Quote We cannot reproduce the DPI issue with our 4K computers.
4K monitors are not very expensive these days. Maybe buy one (or a few)? I suspect many of your customers are using them now. (The extra resolution is super helpful in PCB layout.)
Also, a 4K monitor is not required to simulate the high-DPI issues. In Windows 10, just go to Settings / System / Display, and under Scale and Layout, try all of the standard scales above 100% (125, 150, 200, 225, 250, etc.). This will work even on low-DPI screens, and you should be able to reproduce any high-DPI issues this way. The UI will be huge, of course, but that's okay. That will just make the issues easier to see.
