  New Posts New Posts RSS Feed - "b" Dimension in Mounting Hole
Batiskaff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Topic: "b" Dimension in Mounting Hole
    Posted: 30 Dec 2020 at 6:05am
What does mean "b" dimension?
This is hole dimension that I want to get in MTG or this is diameter of screw that will be insert in MTG?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2020 at 10:35am
For Plated Through-hole the "b" dimension is equal to the hole size.
For Non-Plated Through-hole the "b" dimension should be larger than the hole size. Probably the hole tolerance +/- 0.05 annular ring.
If the hole is non-plated, you want the drill bit to go through FR4 material and not touch any copper to avoid copper slivers in the hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2020 at 2:02pm
So, if i need the Plated Mounting Hole with loose fit of M3 screw i should add a bit to 3 mm. For example: b=3+0,5=3,5mm. After that i should enter 3,5mm in "b" field, will it be correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2020 at 2:16pm
A Plated Through Mounting Hole the b = Hole Size.
b > than Hole size for Non-plated holes.
There is a Hole Size Calculator in the main toolbar "Tool Box".
