  New Posts New Posts RSS Feed - SOT-223 tab pad
SOT-223 tab pad
jhansonxi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhansonxi Quote  Post ReplyReply Direct Link To This Post Topic: SOT-223 tab pad
    Posted: 06 Sep 2020 at 4:02pm
I'm normalizing my SOT-223/TO-261 FPs across multiple manufacturers.  The dimensions I'm using are identical across 4, 5, and 6 pin except for the pitch and pin widths.  I've noticed that with LEP 2019.07 the tab pad size changes along with its corner radii when the smaller pins on the other side change.  For example, the Y size on a 4-pin is 1.8mm but on a 5 or 6-pin it is 1.65mm.  Is this intentional?  What is the rationale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 4:42pm
You are in 100% control of the Preference Options.
If you are using Library Expert Pro, you can select the "Rules" tab and change the "Corner Radius Size" values to anything you want. There is:
  • Corner Radius Size (% of Pad Width)
  • Corner Radius Size Limit
  • Corner Radius Round-off
Change the "Corner Radius Size Limit" to 0.10 and you'll tighten up your corner radius values.
If you get the Free Library Expert Enterprise on a Cloud License you just pay for the yearly maintenance to get all the updates and technical support.
Then you can have access to the Global Preferences so that you set the values once and it applies to every footprint. The Enterprise edition allows you access to over 1,000 preference settings to globally apply to every footprint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhansonxi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 9:06pm
I know I can change it in the preferences.
I can also change it in Altium.
But that doesn't answer my question: Why does the small pin dimensions affect the Tab Pad?
This page was generated in 0.672 seconds.
