  New Posts New Posts RSS Feed - IPC-7351 or Manufacturer Recommended Footprint?
sdavid63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdavid63 Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7351 or Manufacturer Recommended Footprint?
    Posted: 15 Jun 2020 at 8:44am
How to choose between a footprint made with LE and the manufacturer recommended footprint when they are sightly different?
i have made a footprint for the NCP176 (XDFN6 / Case 711AT) with LE and I compare it with the manufacturer recommended footprint.
I notice differences, the MRF does not respect the IPC-7351 design rules (pad to tab iso for example), all the pads are bigger...
How to choose the right footprint for production?
What is your opinion, in a general matter how do you choose the final footprint?
Thanks in advance for your reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 8:59am
IPC-7351 has been downgraded from a Standard to a Guideline.
All of the Preference Values in Library Expert are user definable and you should discuss the rules with your assembly shop and study IPC-J-STD-001 for Solder Joint Goal acceptability.
Library Expert draws the Terminal Lead where the metal hits the pad so you can visually see the Toe, Heel and Side goals.
If the mfr. recommended pattern relocates the Terminal Leads off the pad, this is not acceptable.
Remember that IPC-7351 is a 3-Tier Density Level guideline and maybe the mfr. recommended pattern uses the Most Density Level.
I would say that any mfr. recommended pattern that is between the Least and Most density level is OK to use.
The mfr. could have created a reference design and ran it through stress tests for solder joint goal reliability. It depends on the mfr. Today, all good component manufacturer's test their land patterns.
