  New Posts New Posts RSS Feed - Unable To Execute OrCAD PCB Load .bat
gkm5kor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gkm5kor Quote  Post ReplyReply Direct Link To This Post Topic: Unable To Execute OrCAD PCB Load .bat
    Posted: 08 Apr 2020 at 6:00am
Hello Experts .
Need your kind support to resolve the issue related to library expert  .bat file run .
We use OrCAD PCB editor 17.2 version and did all the setting properly as per the instruction given in the user guide: http://www.pcblibraries.com/products/fpx/userguide/default.asp?ch=205
Output from library expert is executing properly , but when we try to run the .bat file it just flashes and goes off (refer attached video)
uploads/12163/2020-04-08_15h54_50.zip
Are we missing any settings here?
Regards,
Girish Kumar
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 8:27am
Here are the latest instructions for setting up the complex Cadence tools.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 9:14am
Cadence no longer sets up the paths in the environment variables.
This page was generated in 0.984 seconds.
