  New Posts New Posts RSS Feed - Library Expert 2019.07 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2019.07 Released!!
    Posted: 11 Nov 2019 at 10:21am
Version 2019.07 was just released!!
NEW / ENHANCED:
  • Calculator:
    • Add Transformer component family to the SOFL terminal lead form
FIXED:
  • Calculator:
    • Fixed and Naming Convention issue with Through-hole Radial “Inductors, Polarized” – INDP
    • The Through-hole Radial Inductor was throwing an Unhandled Exception Error when moving it to FP Designer
    • Fixed the Polarity Dot issue not coming through from Through-hole component families
    • Fixed an issue with importing a .CSV text file with x/y coordinates
  • Allegro/OrCAD PCB:
    • A Keepout on Top or Bottom inside of a Pad Stack will now be sent to the appropriate ROUTE KEEPOUT layer. Previously, as all pad stacks have a Placement Keepout Restrictions flag, they were going to the PLACE_BOUND layers. Its assumed that the PLACE_BOUND shape will come from the Courtyard, so this should be proper.
  • Altium:
    • Fixed an issue with rounding on ultra-small parts that use non-millimeter units
  • KiCad:
    • Fixed an issue that was rounding the paste mask on thermal tabs
  • Pantheon:
    • Fixed issues with associated copper
