  New Posts New Posts RSS Feed - Grid for Part Creation and Placement
USER2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote USER2 Quote  Post ReplyReply Direct Link To This Post Topic: Grid for Part Creation and Placement
    Posted: 30 Sep 2019 at 10:23am
I have a basic question that i would like to hear opinions -
What grid value we should use for any type of part creation?
Surface Mount and Through-hole both small & big?
What is the placement grid should be used for design?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2019 at 10:42am
It depends on the type of PCB layouts you have. High Density or Low Density.
For PCB layouts that have Low Density part placements, the best PCB library "Pad Size" round-off and "Pad Place Round-off" grid would be 0.05 mm. The Part Placement Grids are 1 mm for large parts, 0.5 mm for medium size parts and 0.1 mm for small parts.
For PCB layouts that have High Density part placements, the best PCB library "Pad Size Round-off" and "Pad Place Round-off" grid would be 0.01 mm. The Part Placement Grids are 1 mm for large parts, 0.5 mm for medium size parts and 0.1 mm for small parts.
Trace Width is 0.1 mm and route grid is 0.05 mm. Here is the routing example where SMD via fanout is on a 0.5 mm grid system placed 1 mm apart.
