SMD BGA Pads |
david.vrtaric
Topic: SMD BGA PadsPosted: 19 Sep 2019 at 1:00am |
I want to create BGA 0.40 mm pitch footprint. So if the pitch is 0.50 mm or less then we should create a SMD ( solder mask defined ) pads. i entered 0.40 mm pitch and BGA Non-Collapsing Ball but the Library Expert is always creating NSMD pads? Is it possible that the Library expert creates SMD pads for BGA per IPC standard? Br.
Posted: 19 Sep 2019 at 8:38am |
Yes, you would use a Non-Collapsing BGA Pad.
IPC has no recommendations on Solder Mask defined BGA pads. This issue is between you and your assembly shop and quality control managers. |
