  New Posts New Posts RSS Feed - Library Expert 2019.06 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2019.06 Released!!
    Posted: 16 Sep 2019 at 9:23am
Version 2019.06 was just released!!
NEW / ENHANCED:
  • Allegro:
    • Pad Stack script generation will now turn on ‘Suppress unconnected internal pads; legacy artwork’, so the user doesn’t have to
FIXED:
  • Preferences:
    • Fixed an issue with IPC-7351B Land Pattern Naming Convention for QFP and QFN component families
  • Print PDF Feature:
    • Fixed an issue where the print PDF feature was only printing the page Header
  • 3D STEP:
    • TO220 Vertical – Fixed issues with the 3D Model generation when D1 exceeded D
    • LCC component family STEP Model generation modified so that the pin 1 marker scales better for smaller parts with pin 1 at the edges. The diameter will now match the width of its lead.
  • Pantheon:
    • Fixed a bug that was causing the Ref Des to improperly generate
    • Terminal Outlines are now suppressed and won’t show in the CAD output, as the [not used] mapping wasn’t working in modern Pantheon
