  New Posts New Posts RSS Feed - HARWIN M20-7812045 Size of Pin 1 Marking
toshas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Topic: HARWIN M20-7812045 Size of Pin 1 Marking
    Posted: 31 Aug 2019 at 9:14am
Hi!
I tried to change size of pin1 mark in HARWIN M20-7812045 footprint with no success.
Drafting - Legend - Pin 1 Size - OK. Nothing was changed.
What is the right way to do it ?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 9:59am
For all FP Designer connectors, do this...
Right Mouse Button (RMB) and select "Shapes".
Double Click on the Polarity Marker.
A dialog box should appear, but if the Polarity Marker is selected just RMB and select "Properties"
Then select any new shape, change any layer, change the size and location.
Note: if the Polarity Marker is filled, unselect the Filled button after you change the size and then reselect the Filled button to refill the shape.
Then Apply and exit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 10:33am
Got it! Thanks!
This page was generated in 0.227 seconds.
