  New Posts New Posts RSS Feed - Library Expert 2019.05 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2019.05 Released!!
    Posted: 01 Aug 2019 at 3:12pm
Version 2019.05 was just released!!
NEW / ENHANCED:
  • Drafting Symbols:
    • Added Bottom Solder Mask layer
  • Altium:
    • Changed the default Target Library form “Use Existing” to “Create New”
 FIXED:
  • Drafting Symbols:
    • Fixed an issue when re-selecting the Drafting Outline on the Top Solder Mask layer, the Preference setting flipped back to Top Legend
  • Calculator:
    • Fixed the Mounting Hole Footprint Name bug
  • 3D STEP:
    • QFP – Fixed an issue that was causing the body to have errors
    • QFP w/tab – A minimum standoff of 0.02 mm is enforced to make sure the thermal tab model does not break
  • Altium:
    • Fixed a problem where the Assembly Ref Des wasn’t getting the proper Width value
