  New Posts New Posts RSS Feed - The Mirror Feature in BGA Does Not Mirror 3D STEP
RobVanSchelven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobVanSchelven Quote  Post ReplyReply Direct Link To This Post Topic: The Mirror Feature in BGA Does Not Mirror 3D STEP
    Posted: 07 Jul 2019 at 11:49pm
in BGA after doing a mirror function, the pin 1 dot indicator in the step file does not move to the new pin1 location
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 7:18am
The only reason to Mirror a BGA is to temporarily flip it to see the "Bottom Side" so you can match the Datasheet "Bottom Side" for the removal of pins. It makes it easier when the Footprint and Datasheet match to unpopulate pads.
After you completed the Footprint, you must unmirror the BGA as there is no such package as a Mirrored BGA in your library.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobVanSchelven Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 7:38am
Thank you, i get it.
This page was generated in 0.441 seconds.
