  New Posts New Posts RSS Feed - PCB Library Expert PTH Reference Calculator
pholden7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pholden7 Quote  Post ReplyReply Direct Link To This Post Topic: PCB Library Expert PTH Reference Calculator
    Posted: 03 Jul 2019 at 5:54am
Is there a version of this that uses "Proportional Padstack" calculations?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 7:30am
The PTH Reference calculator and Library Expert Through-hole calculators use what we refer to as incremental pad stack calculation.
The Hole Size is calculated over the maximum Terminal Lead and the pad stack is 1.5 X the Hole Size.
A 0.50 mm Hole = 0.75 mm pad size or 0.125 mm annular ring, but the minimum annular ring overrides that. If your minimum annular ring is 0.20 mm then the pad size would be 0.25 mm
A 1.00 mm Hole = 1.50 mm pad size or a 0.25 mm annular ring.
A 2.00 mm hole = 3.00 mm pad size or a 0.50 mm annular ring.
Terminal Leads that create large hole sizes probably carry a lot of current or the package is big and bulky and has weight to support. That is the main reason for the larger Annular Ring. To support the package weight and voltage current. Requires additional solder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 7:33am
In Library Expert Enterprise, the through-hole pad stack settings are in -
Preferences > Terminals > Through-hole > Pad to Hole Ratio & Minimum Annular Ring
In Library Expert Pro, the through-hole pad stack settings are in the Calculator Panel > Terminal tab.
