  New Posts New Posts RSS Feed - Courtyard Excess Value For Non Standard Packages
Batiskaff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Topic: Courtyard Excess Value For Non Standard Packages
    Posted: 03 Jul 2019 at 3:24am
What are the general recommendation for values of Courtyard to Body and Courtyard to Pad Excesses for non-standard packages?
For example:
https://media.digikey.com/pdf/Data%20Sheets/Cooper%20Bussmann%20PDFs/EM7117xx_Series.pdf
https://www.cui.com/product/resource/pj-002a.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 7:18am
Nominal Density Standard Components use a 0.20 mm courtyard excess.
Unique Non-Standard packages us a 0.25 mm courtyard excess, but if any dimension L, W & H are over 10.00 mm then we make the courtyard 0.50 mm to make room for rework equipment. This is mostly connectors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 9:08am
Thank you Tom.
5not4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 5not4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 8:33am
Tom,
Is this for revision B or C? It seems to me most nominal courtyards in the B version are .25mm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 8:42am
Over the past 5 years, we have been using these Courtyard Excess values for "Standard Packages" that were tested by customers and reported great results. This has nothing to do with IPC.
  1. Most = 0.40
  2. Nominal = 0.20
  3. Least = 0.10
The original IPC-7351B Courtyard Values were created in 2004 and are now 15 years old.
New technology for Assembly machines has improved placement accuracy down to +/- 0.01 mm.
There is no need for a 0.25 courtyard as it consumes too much PCB real-estate for densely populated layouts.
Also, IPC-7351 has been downgraded from a "Standard" to a "Guideline" and is not to be taken literally.
You must use your own common sense and advice from your assembly team to create your design rules.
This page was generated in 1.703 seconds.
