  New Posts New Posts RSS Feed - Polarity Bar on Diodes
kvachhani View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kvachhani Quote  Post ReplyReply Direct Link To This Post Topic: Polarity Bar on Diodes
    Posted: 22 May 2019 at 9:12am
Currently working on Polarized Diode with small footprint. See Attached Lib-Exp-Polarity-Bar.pdf.
Expert complains about creating legend due to small footprint, but does not even create the polarity marking bar.
If I turn on polarity dot, it creates dot. It would be nice if it created bar for polarity marking even if it can't create silkscreen for Diodes and Polarized Capacitors.
Ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 9:28am
Library Expert does not put Silkscreen Legend on small parts due to the Preference settings in the Drafting section. You Line Width and Gap and preventing Library Expert from adding Legend Outlines.
However, you have 100% control of all the Legend Marking that you want.
Any Shape, Size, Location, Filled, Unfilled, Layer using the Drafting Symbols feature in the toolbar.
These are used when your micro-miniature part violates your Preference Settings. Then you can add anything you want per these shapes:
You add the Polarity Bar and Library Expert will save all your drafting outlines to FPX.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kvachhani Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 10:43am
Thank you. Can you point me to a document that will walk me thru adding these manually. Are these shapes pre-drawn in the tool somewhere?
thx
Ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 10:48am
Here is a short video that explains the basics, but your only limited by your imagination on how you can use this feature.
