  New Posts New Posts RSS Feed - Importing an existing footprint
tjnash75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjnash75 Quote  Post ReplyReply Direct Link To This Post Topic: Importing an existing footprint
    Posted: 19 May 2019 at 8:07am
I've discovered a mistake in a footprint I generated (my mistake, not the tool's).
This is a footprint I made a while ago, so the output files exist, but the footprint is no longer loaded in the PCB Library Expert GUI.
Do I have to remake the footprint from scratch, or is there a way to import the output files back into the tool to get my footprint creation session back?
Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 8:34am
There are backup files in this folder -
C:\Program Files (x86)\PCB Libraries\Library Expert 2019\Libraries\Backups
But it depends how many backups you have set in Preferences.
Is this a Calculator part or FP Designer?
If it's a calculator part, then all you need to do is re-enter the package dimensions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjnash75 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 8:50am
It's a calculator part.
Call me lazy, but I was trying to avoid having to type all the dimensions in again and make sure all of the options I wanted are set correctly (analogous to when you can't find the TV remote so you just sit there watching a show you have no interest in, instead of looking for the remote).
Thanks Tom!
