  New Posts New Posts RSS Feed - Library Expert 2019.03 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2019.03 Released!!
    Posted: 13 May 2019 at 11:44am
Version 2019.03 was just released!!
UPDATED / FIXED:
  • Altium:
    • Fixed an issue where round pads were accidentally getting rotated 10 degrees
  • Xpedition:
    • Fixed an issue with multiple paste mask or solder mask, should it include both polys and rectangles. Everything for a layer of a pin, should now be put into one complex pad.
    • Removed the deprecated “Direct Import” option (as it’s obsolete)
  • CADSTAR:
    • Adjusted the Drill Orientation so that it nomalizes to a number between 0 and 360. I.e. -90 will become 270. CADSTAR does not allow for negative rotations on the drill orientation.
    • The LASUBTYP line will now be excluded from output
  • Allegro/OrCAD PCB:
    • Fixed a problem that was causing custom parts with through holes to set the thermal pad to 0 diameter
    • Fixed a problem that was causing duplication of associated copper that contained arcs
  • General:
    • An updated rounding has been added for non-millimeter values across all translators. This should hopefully round numbers that are very close to their actual number properly. Ex: 5.9998 to 6 or 5.1996 to 5.2. Millimeter values don’t have the issue, as they’re the native units.
