Most, Nom, Least Environment - Tab Menus |
RLS2004
Joined: 26 Jan 2012 Location: Seattle,WA Status: Offline Points: 51 |
Topic: Most, Nom, Least Environment - Tab MenusPosted: 29 May 2012 at 4:58pm |
I'd like to compare footprint dimensions, comparing M, N, L environments. When I switch environments the window changes to display component dimensions.
Would it be appropriate to remember the tabs in use instead of jumping to Component dimension tab? |
Posted: 22 Oct 2012 at 9:43am |
To compare Least, Nominal and Most pad sizes and their differences, I recommend that you open 3 sessions of the PCB Footprint Expert.
I hope you use 2 LCD monitors. |
