  New Posts New Posts RSS Feed - Are librarians adding a pin one dot to tiny comps?
lsday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsday Quote  Post ReplyReply Direct Link To This Post Topic: Are librarians adding a pin one dot to tiny comps?
    Posted: 29 Mar 2019 at 8:30am
I am getting quite a few die size components. I am wondering about the pin one marking. Should I mark it? Should the dot size be less than 20 mils?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 8:37am
A 15 Mil dot is about the smallest for both the fabrication shop and the human eye.
Why not box Pin 1 in a square? Or are the pins too close?
These are the Polarity Marking in Library Expert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsday Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 8:56am
I will try the box method. Thank you Tom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 9:05am
If you're in FP Designer, temporarily move the origin to Pin 1 and then place the box a 0,0 and make the line width minimum 0.10 and make the box 0.15 larger than the pad.
Box size = 0.10 line with 0.10 space + pad size.
If you use a 0.12 line / 0.12 space then make the box 0.18 larger than the pad.
This page was generated in 0.377 seconds.
