  New Posts New Posts RSS Feed - SOT23 package with 2019.02
jnshah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnshah Quote  Post ReplyReply Direct Link To This Post Topic: SOT23 package with 2019.02
    Posted: 17 Mar 2019 at 4:51pm
Is there a footprint naming convention change for SOT23 packages?
When I update any existing package in my library, it asks me to update the footprint name when saving back to library and changes the name.
For example, SOT23-3P50_160X90L22X22 changes to SOT23-P50_160X90L22X22.
I see that with every SOT23 package in my library (20+ items).
I have not tried others.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2019 at 5:38pm
The new IPC-7351 Land Pattern Naming Convention pushed the Pin Qty from the end of the Footprint Name to the beginning.
So, SOT23-3 or SOT23-5 or SOT23-6 or SOT23-8 is the common pin qty of the SOT23.
The P95, P65 & P50 is the Pin Pitch - 0.95 mm or 0.65 mm or 0.50 mm pitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnshah Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2019 at 5:54pm
Thanks for the quick reply. Just so that I am clear, SOT23-3P50 now becomes SOT23-P50? The "3" before the P50 goes away? The new footprint name I am getting is "SOT23-P65_210X110L32X32" and it does not have the pin number in it at all. How do I tell if it is a 3P vs 6P vs 8P?
Is this change new to 2019.02?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 8:20am
The Land Pattern Footprint Naming convention was updated in Library Expert V2017.
Look in this folder on your computer -
C:\Program Files (x86)\PCB Libraries\Library Expert 2019\Documents
You will see these very important documents -
  • Library Expert Land Pattern Naming Convention.pdf
  • Library Expert Surface Mount Families.pdf
  • Library Expert Through-hole Families.pdf
  • Library Expert Solder Joint Goal Tables.xlsx
  • PCB_Library_Expert_SMD_Reference_Calculator.zip
  • PCB_Library_Expert_PTH_Reference_Calculator.zip
zetski210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zetski210 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 8:47pm
I'm also seeing the pin number disappear from the SOT23 parts in v2019.
This means that the same land pattern is called for either 3, 5 or 6 pin parts with the same geometry.
I cannot use this approach as my CAD library wants to over-write the files (as they are all the same name) and my CAD package will fail as there is the same land pattern for 3/5/6 pin parts...
Reverting back to v2018 until this is corrected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 9:40am
The SOT23 Land Pattern Footprint Name has been corrected in V2019.02.
Post Options Post Options   Thanks (0) Thanks(0)   Quote zetski210 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 3:42pm
Thanks Tom.
