  New Posts New Posts RSS Feed - Silkscreen-legend
Silkscreen-legend
kvachhani View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kvachhani Quote  Post ReplyReply Direct Link To This Post Topic: Silkscreen-legend
    Posted: 25 Feb 2019 at 5:02pm
Since you can't have silkscreen on pads, is it possible to offset silkscreen outside of the courtyard/outline?
This will save lots of time to clean up/move silkscreen off the pad after the board is routed.
thx
Ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2019 at 7:24pm
Library Expert does not allow Silkscreen Legend on pads.
It auto-trims per your Preferences in Drafting > Legend.
There is a Legend > Clearance option.
Also, you control the Courtyard in "Drafting > Courtyard" Preferences.
If you're using the Library Expert Pro, just select the "Drafting" tab in the package dimension panel. You must do this for every part you create.
If you're using Library Expert Enterprise, open Preferences > Drafting and just set it once and it applies to every part you create automatically.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kvachhani Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2019 at 6:56am
AHH... I should've known, you thought of everything. I guess, I should go thru the manual and learn it correctly. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2019 at 8:34am
There are 70 educational videos in "Help > Topics"
Or you can watch them anywhere here -
