  New Posts New Posts RSS Feed - No 3D STEP Polarity (1pin) Marker on SOIC Packages
toshas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Topic: No 3D STEP Polarity (1pin) Marker on SOIC Packages
    Posted: 16 Jan 2019 at 9:28am
Hi!
Unable to find polarity (1pin) marker on 3D step model.
Particular part - MCP23016-I/SO from Microchip.
Is it feature or bug ?
Thanks a lot!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 6:09pm
Are you using the new V2019.01 Library Expert?
The new release has updated SOIC 3D STEP polarity marking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 10:32pm
I haven't access to V2019.
So I'm on V2018 right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 8:13am
The V2019.01 will be released soon to every one and the 3D STEP Polarity Marker is fixed.
We're just waiting for the programmers to put the finishing touches on it.
Someone reported this a couple weeks ago and it was fixed immediately for the Enterprise users in V2018.10 pre-release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 1:28pm
You can now get the 2019.01 Pro from www.PCBLibraries.com/Downloads
Regards,
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 2:00am
Thanks for the 2019.1 !
Actually not difference, mark on 3d doesn't exist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 9:36am
Can you send me the FPX you used to generate this part? I'll take a look at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 10:34am
I downloaded it from POD.
Manufacturer: Microchip
Part Number: MCP23016-I/SO
Case Code: C04-052
Datasheet: Download PDF
Footprint Name: SOIC28P127_1786X1034X264L83X43
I can upload .fpx but it is signed for my pod-key. I think it will not work on other pc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 12:30pm
The polarity marking for 50 mil pin pitch SOIC's is the chamfer along the top edge.
Metric pitch SOP's have a pin 1 dot (not inch based SOIC's).
This page was generated in 0.289 seconds.
