  New Posts New Posts RSS Feed - Library Expert 2018.09 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2018.09 Released!!
    Posted: 06 Dec 2018 at 4:48pm
Version 2018.09 was just released!!
NEW / ENHANCED:
  • Small Outline L-Lead (SOL)
    • Added a 10 and 12 pin version
    • When selecting Create New Row, the new columns “Mounting Type” and “Part Status” are automatically added
      • Mounting Type = Surface Mount or Through-hole
      • Part Status = Active or Obsolete (Not Recommended for New Designs = Obsolete)
FIXED:
  • Calculator:
    • Vertical Header: Fixed an issue where selecting the Center of Pins origin feature did not work correctly
    • PSON with Tab: Removed an unnecessary warning message
    • Fixed a bug where the program throws an Exception Error when the Find feature stays active when opening multiple FPX files
  • 3D STEP:
    • QFN: Fixed an issue with the 90 degree Wrap Around Lead model
    • SOP: Fixed an issue where the Body Cavity and Polarity Marker were not filling in properly
  • OrCAD PCB:
    • Fixed a .bat command line from Allegro –orcad to Allegro -product OrCAD_PCB_Editor_basics
  • Altium:
    • Fixed a problem that was drawing two identical Keep Out All shapes
  • CR-5000/CR-8000:
    • Fixed a crash bug with CR-5000 pad stacks which have more than one area of paste mask
