  New Posts New Posts RSS Feed - 3D Model Using PCB Library Expert Pro 2016
rafiq234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rafiq234 Quote  Post ReplyReply Direct Link To This Post Topic: 3D Model Using PCB Library Expert Pro 2016
    Posted: 12 Nov 2018 at 7:22pm
I purchased and using PCB Library Expert pro 2016 with Altium Designer.
If I create a new component, with the information I entered (Length, height, width...) in the settings, the 3D will be generated correct?
I could not find any 3D body in the Mechanical Layer 13 (Mechanical Layer 13 assigned for 3D Model in Altium).
Do I need to import 3D model? If I don't import 3D model, PCB Library Expert Pro 2016 will generate based on the information provided?
Regards,
Rafiq
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 7:34pm
In the Library Expert translator dialog window, there is a check box for 3D STEP. Did you check it?
The folder name for the script file should be the same folder for the 3D STEP file.
Look in that folder to see if there is a STEP file in there.
Also, the Vertical Axis in the Translator window should be set to "Z axis".
You can also get V2018.08 Library Expert Pro for free. It will install into a separate folder so you can use both V2016 and V2018.
This page was generated in 0.922 seconds.
