  New Posts New Posts RSS Feed - Footprint for US8 US SUFFIX CASE 493
girishv6991 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote girishv6991 Quote  Post ReplyReply Direct Link To This Post Topic: Footprint for US8 US SUFFIX CASE 493
    Posted: 24 Sep 2018 at 8:17pm
I want to create a surface mount footprint for OnSemi NL17SZ74. According to datasheet the package is US8 US SUFFIX CASE 493. Which template I should be using in "Library Expert Pro"
Girish
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2018 at 7:30am
Small Outline Package (SOP).
That entire component family is on www.pcblibraries.com/POD and it tells you the Case Code and component family.
Also, there is a document on your computer in this folder -
C:\Program Files (x86)\PCB Libraries\Library Expert Pro 2018\Documents
File Name: Library Expert Surface Mount Families.pdf
