  New Posts New Posts RSS Feed - Molded Body - Diode shows no polarization
Olaf.MuellerAE View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Olaf.MuellerAE Quote  Post ReplyReply Direct Link To This Post Topic: Molded Body - Diode shows no polarization
    Posted: 01 Jun 2018 at 2:32am
Hello all,
I tried in 2018.04 and 2018.05 a SMD Diode with Molded Body. But it shows no polarization.
There is no difference between "Diode" and"Diode - Non polarized", also with capacitor and inductor.
Best Regards
Olaf
Ian S View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ian S Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 3:41am
It works for me in V2018.05
Check the following Preferences and adjust to suit.
1. Drafting>Assembly: 'Include Polarity Indicators'
2. Drafting>Legend: 'Autogenerate Pin 1 Indicator Line'
3. Rules: 'Cathode/Anode Pin Names'
Ian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2018 at 10:48am
The big difference between Polarized & Non-polarized Molded Body Diodes is the 3D STEP model.
The Legend & Assembly auto-polarity markings can be set in Preferences > Drafting > Legend & Assembly > Polarity
However, it's vastly superior if you add your own unique Legend and Assembly polarity marker using the Drafting Outline icon in the Calculator toolbar and then save that data to FPX.
