  New Posts New Posts RSS Feed - Paste Mask Question
Paste Mask Question
vavouris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vavouris Quote  Post ReplyReply Direct Link To This Post Topic: Paste Mask Question
    Posted: 24 May 2018 at 5:50am
I'd like to ask what is the general guideline for paste stencils.
Should the stencil be same size as the pad, smaller or greater?
I know that in BGA packages we want very few solder paste on the pad. And on other packages, I was creating a paste mask figure 70% of the pad.
I am a bit confused now, and I don't know if should continue to do that or leave it 1:1 and let the assembly plant deal with it.
Theocharis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 6:08am
For Standard SMD pads the Paste Mask aperture size is 1:1 scale.
For Thermal Tab pads the Paste Mask Reduction is between 40 - 60%.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vavouris Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 6:15am
Thank you! That was fast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 6:19am
If you use Rectangle Pad Shape, the Paste Mask aperture will be Rounded Rectangle, so you might as well use Rounded Rectangle for the pad shape too.
This page was generated in 2.453 seconds.
