  New Posts New Posts RSS Feed - Library Expert Pro Default CAD Tool At Startup
btm3678 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote btm3678 Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert Pro Default CAD Tool At Startup
    Posted: 30 Apr 2018 at 8:01am
I receive a default CAD tool prompt every time I start up Library Expert.
I would assume the normal behavior would be for this to go away after the default tool is chosen.
Is this a known issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 11:36am
Talked to the programming team and this issue will be resolved in V2018.05.
The intention was to eliminate 10's of thousands for user questions regarding:
"How do I change the Default CAD tool?"
So we added this dialog box at the startup to eliminate all the questions and it worked.
Now you're asking:
"How do we get rid of this dialog box every time we run LE Pro?"
The answer seems to be, show it once on the first run of the program and hope everyone remembers how to change CAD tools.
We could put a button in the dialog that says: "Don't show this message again", but that feature would mess with your registry and force the program to look there every time the program opens.
This is not an option for many users as they want to keep their registry clean.
This page was generated in 0.220 seconds.
