  New Posts New Posts RSS Feed - Tolerance
Tolerance
Hassan Moaaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hassan Moaaz Quote  Post ReplyReply Direct Link To This Post Topic: Tolerance
    Posted: 11 Apr 2018 at 8:52am
Why i can't generate footprint with tolerance not equal plus and minus and when i add values as example below it change automatically
As example  D = 1 - 0.1 +0.2 ? to be  1.05 +/- 0.15
Also How can i generate footprint for package SOT-89 it found in reference but i can't found in tool
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 10:54am
When you have different +/- tolerances, enter the Min/Max data instead of Nominal + Tolerance.
When you enter the Min/Max data, a new Nominal dimension will be auto generated.
The Nominal = the value between the Minimum and Maximum.
This will also affect the Footprint Name, which uses the Nominal dimensions.
Batiskaff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 4:50am
+1 good question. How to сreate SOT-89?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 7:29am
SOT-89 has an irregular shape pin 2 and it's a different shape and size for every mfr.
Library Expert cannot auto-generate irregular pad shapes yet as this requires associated copper poly shapes.
We manually create SOT-89 and upload them to POD.
Check the mfr.'s Diodes and NXP for the Case Code SOT89 or SOT-89 and download those parts.
If you have a new SOT-89, we'll be glad to build it for $5 and share it with everyone else for free download.
This page was generated in 1.109 seconds.
