  New Posts New Posts RSS Feed - Library Expert 2018.02 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2018.02 Released!!
    Posted: 30 Mar 2018 at 10:00am
Version 2018.02 was just released!!
NEW / ENHANCED:
  • Preferences:
    • The default LGA pad shape was updated from “Rounded Square” to “Square”
    • Added a new SAMPLE BOM.xlsx file for FPX to BOM compare demo
    • Doubled the size for pad stack creation. Was limited to a 25.4 mm pad size.
  • Library Expert Pro:
    • Added a notification in the CAD tool translator dialog box on how to change CAD tool formats
FIXED:
    • Fixed an issue with Silkscreen Legend Outline. An outline that had no cuts was coming out as a non-closed polygon.
  • 3D STEP:
    • The 3D STEP model for MELF Diodes was not being created correctly. The polarity band was cutting through the body.
  • Xpedition:
    • Fixed an issue when generating “Unique” parts that were originally created in PADS Layout and inserted into FPX.
  • PADS Layout:
    • Fixed an issue where in some installations, Extended Layers was the default.
