  New Posts New Posts RSS Feed - Gap between Pattern Defined Solder Mask
robmeyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robmeyer Quote  Post ReplyReply Direct Link To This Post Topic: Gap between Pattern Defined Solder Mask
    Posted: 30 Mar 2018 at 6:04am
I think it would be a nice thing when we could define a min gap between Solder Mask Pattern on Thermal Tabs.
For now you have to push it to Footprint Designer and hack this value. With a min gap setting this step will be go away and I can't forget it.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 6:51am
Do you mean Paste Mask Pattern?
Please clarify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote robmeyer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 7:21am
Yes you are right, I found a min gap in the Paste mask pattern really usefull. I called it Solder Mask Pattern, because the option in the tool is called like that.
Robert
