Vertical PTH Header 8x2 |
BennsPCB
Joined: 30 Jan 2013 Location: Sweden Status: Offline Points: 98 |
Topic: Vertical PTH Header 8x2Posted: 21 Mar 2018 at 2:51am |
Hi!
"Assembly drawing top" and "component outline" does not work for other sizes than 4x2. I am using LEEE 2018.02 Cheers /Benn |
Posted: 21 Mar 2018 at 5:45am |
Is your "D" dimension 20.32?
We need to see your other settings. Are you available to do a webcast so we can see what you are doing? ![]() |
BennsPCB
Posted: 21 Mar 2018 at 7:33am |
Hi Tom. Problem solved!
You are right. It was a typo in D-dimension that was the problem. Still, I'd like to get a warning if such an obvious error occurs. Cheers, /Benn |
Posted: 21 Mar 2018 at 7:35am |
You do get a warning...
The footprint looks screwed up. That's your warning. ![]() |
