  New Posts New Posts RSS Feed - Solder Mask Defined Variant
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: Solder Mask Defined Variant
    Posted: 26 Feb 2018 at 7:56am
Is there a quick way to generate SMD footprint variants for parts?
I'm looking at power parts where some pins have skinny traces connecting to them, and others have planes.
I want SMD footprints to prevent uneven solder height due to spreading during reflow.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 8:14am
By "Variants" are you referring to Library Expert Preferences?
Can you provide some real application examples?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 10:16am
This is mostly an issue with power components, which require thick traces or pours to certain pads for electrical or thermal dissipation reasons.
An example would be a dual power transistor in a leadless package where the sources and drains have to be directly connected to pours for heat dissipation, but you want skinny traces to the gates to minimize capacitance. With NSMD pads, the pour-connected pads end up with extra exposed copper.  They are effectively starved for solder paste, since the paste only covers the nominal pad area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 10:44am
All of this can be done in FP Designer.
FP Designer is available in both V2018.02 Library Expert Pro and Enterprise.
You have complete pad stack design and placement control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 10:53am
Can it be done just through a preferences file? I often already have a part entered that I'm using in a new way, and I need a version with NSMD pads. It would be great if I could just pick a set of preferences and pop out a new footprint. If not, it's no big deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 10:59am
The preference file only has settings for "Terminal Lead" styles like Gull Wing, J-Lead, Flat Lead.
Preferences are mainly used for the Calculator to auto-generate patterns.
However, you have 100% full editing rights to adjust the Toe, Heel and Side goal for any Terminal Lead form.
You also have a preference for Thermal Tab Paste Mask Reduction.
I think you need the ability to create custom pad stacks and FP Designer does that.
This page was generated in 0.797 seconds.
