  New Posts New Posts RSS Feed - QFN Pad Calculation Problem
robmeyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robmeyer Quote  Post ReplyReply Direct Link To This Post Topic: QFN Pad Calculation Problem
    Posted: 08 Feb 2018 at 4:58am
when I try to generate a QFN with Version 2018.02 the Pads are to small, see picture. I also add the fpx to this post. uploads/870/QFN_error.fpx When I make D2 shorter (0.8mm) then the footprint looks good. Looks like the calculation takes the removed Pins also in it or something else is wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 9:53am
The problem here is that you are using the QFN (Quad Flat No-Lead) component family to create a SON w/Tab (Small Outline No-Lead) footprint.
Try using the SON with Tab and you'll get perfect results.
There is no bugs or issues with V2018 Library Expert.
This page was generated in 0.395 seconds.
