  New Posts New Posts RSS Feed - Footprint Error Pad-Pad clearance fail
wawaus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wawaus Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Error Pad-Pad clearance fail
    Posted: 22 Jan 2018 at 11:54pm
Generating a footprint for a Vishay-Siliconix DG2722 Library fails to maintain the specified Pad to Pad clearance with the clearance rule set at 0.2mm. Between pads 1-10, 2-3, 5-6, 7-8  it delivers a clearance of only 0.14. To achieve the clearance, dimension S1 should have increased to 1.0mm.
Is this behaviour expected?
Have I missed something?
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 7:33am
I cannot find this part on www.pcblibraries.com/POD ;
The Vishay DG2722 datasheet -
Indicates that the footprint requires a longer Pin 1 and therefore must be created in FP Designer using the mfr. recommended pattern
The Preferences > Rules > Minimum Pad to Pad is for Standard Calculated parts only and does not have anything to do with custom FP Designer footprints that use the mfr. recommended patterns.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wawaus Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 2:48pm
I accept your comment about the Mfr recommended pattern, but that does not change the fact the calculated footprint Did Not maintain the clearance I specified between the end of one calculated pad and the side of another adjacent calculated pad.
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 2:53pm
I don't know how you created a QFN with a longer Pin 1 in the Calculator, it does not have that feature.
Send us the FPX file for this Calculator part and your Preference .dat file so we can take a look.
Never seen this issue in the past 15 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wawaus Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 7:50pm
I did not create it with a longer pin 1, I created a symetrical footprint, but with a 0.2mm clearance requirement the corner pads are closer than the the clearance specified and there was no warning that the rule had been violated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wawaus Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 7:53pm
I tried to add some screenshot snips but they appear not to have gone through.
